Screwdriver's 120k Mile Tune Up
Timing Belt - Done
Water Pump - Done
Tensioner - Done
Radiator Drain/ Fill - Done
PCV- Done
Oil/ Filter - Done
Fuel Filter - Done
Tranny Oil Flush and change- Done
New Wipers - Done
Brake Oil - Changed 15K ago
Plugs/ Wires - Iridiums with 20K on them/ PRD Wires
Air Filter - K&N in good shape
Pending Items for next couple weeks:
1) Non Captive Swap with New Front RotorPros Rotors and Pads
2) New KYB Struts
3) New Power Steering Fluid Drain/Fill
Did I miss something? Is there anything else that can be done to weatherproof the car?
Thanks
V V V Added Brake Oil to the list. Thanks MJ
Water Pump - Done
Tensioner - Done
PCV- Done
Oil/ Filter - Done
Fuel Filter - Done
New Wipers - Done
2) New KYB Struts
Thanks
leak down? if you have a propane tank with attachment and a gauge it can be done pretty easily. get two people, one to listen for hisses (leaks)
