Revs go up but no speed increes
ok l8tly i been having this annoying issue with my 03 tiburon gt 5 speed....in any gear the car runs n drives fine, with normal gas is being given rpm's and power are normally increesing. But when i put it to the floor the RPM gauge shows a HUGE FAST increese in RPS's n fast almost like the tires are spinning on ice but the tires arnt and the speed goes up VERy slow...
when i just give it gas normally slow and dont pin it to the floor the rpm's and speed increes normally without issue....the only time it happens is when i step on it.... cause? im guessing it might be my clutch....anyone? |
Clutch... and is "lately" really that difficult to spell?
Oh, and get off my lawn. |
Clutch
thought so! well looks liek ill be doing a clutch this summer! one more question. when i look at clutch selections says there are 2 diffrent kinds dual mass or solid flex plate....i was told to put a solid flex plate in instead as apparently dual mass sucks...
Dual mass softens engagement. Used mostly in German cars. Stick with a solid flywheel.
Get a Fidanza lightweight flywheel with your clutch, and you'll love driving your car much more. :)
If your clutch is slipping, it will only get worse. Every time you floor the gas and feel it slipping, you are contributing to the problem. Baby the gas pedal and get parts together . . . this is a warning period, and the switch from "drivable" to "towed home" can happen quickly when the last of the good portion of the clutch decides to let go.
