O2 Sensor
The dealership told me that the o2 sensor needs to be replaced, which o2 sensor would cause the car to bogg and lose power, the exhaust or the manifold sensor? They both look the same!
I have any aftermarket sensor, im not sure which one i should replace.
It would be the 1st one that controls the fuel trims. That's most likely your problem. To save a bit of cash and remove some of the symptoms quickly, you can swap the two sensors around. The 2nd one is not as important to vehicle operations as the first.
