Ok on my 2000 I dont have a rear o2 connector and there hasnt been a sensor there, just wires. I need someone to go out and look for me which wire connects to what.
It will be to a bosch o2 sensor, the colors are: white - heater white - heater black - signal gray - ground All the wiring diagrams I can find dont have my wire colors which are: brown yellow red/white pink/white Thanks! |
hey, that's how mine are, unfortunately, my tib is 170 miles away
Hmmm, did I post these when I did my sensor relocation DIY? I can't remember man.
I can tell you when I get home I think. |
I searched around but didnt see that thread. Ill check. Thanks
Redz, if you (or anyone else) could check that would be great. I found the DIY and it doesnt list the colors. Thanks |
My rear o2 sensor is currently IN the car, BUT I've got my wideband out of the car, and it's wired PnP, so I can give you pics and all if you'd like.
Between that and a wiring schematic from HMAService, you should be good. |
I do need some good pics of the LC1 all wired in to be PnP.
If anyone can check the rear wires for the O2 I still need that. HMAService had the wrong colors. |
the problem is that the wire colors differ year to year. i have like 3 different O2 pig tails and all of them have diffent colors.
hopefully this might will help... https://i117.photobucket.com/albums/...igensensor.gif |
For future reference if anyone searches for this the correct wiring is:
pink/white goes to white (heater) red/white goes to white (heater) yellow goes to black (signal) brown goes to gray (ground) |
any1 know the wiring of yellow/green, red/white, gray, and black?
wiring from the ecu side to bare wires from oxygen sensor |
bump
