Need Help Asap
Vehicle: 01 Tiburon
what the heck is wrong anyways? if you could let us know maybe we could try to help you troubleshooting?
have you checked your fuses, relays or the fusible links?
I have heard of alternators still being bad, even if they test good. And your battery, what's it's cold cranking amperage rating?
Well after putting the starter back on and giving up for the night i gave it one last shot, hit the starter works like a charm. Has worked fine ever since i dont know what the problem actually was but thatnks for the input anyways.
Most likely the corrosion on that wire like alex said.
Itll come and go, just like a badly corroded battery terminal, sometimes itll work sometimes it wont.
And most likely itll happen again if you dont take care of it, but when it does youll know where to go to take care of it.
