Low Fuel Level Lamp
Vehicle: Elantra HD / 2007
When I have almost empty fuel tank, low fuel level lamp is not ON.
When I took fuel pump assembly out of the tank lamp didn't shine also.
I checked the lamp by connecting 2 pins in the fuel pump harnes and lamp worked.
What to do? is it possible to change only Low fuel sensor?
well just for reference here's my findings.
we have a 14.5 gallon tank. after I use 10 gallons it hits E. use one more gallon and the fuel light comes on.
Vehicle: 2004 Acura TL
Prolly something along the way back to the cluster. Could be anything. Rip your entire car apart and double check all the wiring. lmao.gif
<div class='quotetop'>QUOTE (jpv8220 @ Nov 18 2005, 03:08 PM) <{POST_SNAPBACK}></div><div class='quotemain'>my light fades in and out it never stays on</div>
Yeah so did mine. If I was low and I was getting on the highway it would fade in, then once on the highway, it would fade out.
But now, it stays on. I almost ran out of gas when tibby01 was doing my gauges and it's been on ever since. I have the exact opposite problem.
<div class='quotetop'>QUOTE (silvertibbs @ Nov 20 2005, 04:41 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Prolly something along the way back to the cluster. Could be anything. Rip your entire car apart and double check all the wiring. lmao.gif</div>
I checked wiring by connecting wires on fuel pump harness. Light come on.
Vehicle: 97 Tib
It does fade in and out.
That is, until your tank gets so low that it stays steady and bright, that means you have about another 15-20 miles until you stall.
