Loose power windows
Old Feb 26, 2015 | 09:32 PM
bigfishmoney's Avatar
Default Loose power windows
Windows loose on drivers and passenger side doors. When slamming the door
Where can I adjust this part?
Old Feb 26, 2015 | 10:02 PM
tibbytib's Avatar
Just take the door panel off and inspect the regulator. Might just have some loose nuts & bolts. Could be an easy fix.
Old Feb 27, 2015 | 07:19 AM
JonGTR's Avatar
I've had the window bracket come loose on other cars. Simple fix.
Old Aug 4, 2015 | 01:28 AM
krazytib's Avatar
I had a loose drivers side window before. I waited too long to fix it and then one day I was rolling the window down and BLAM, the window fell inside the door. Luckily it didn't break.
The regulator wire had cut through the plastic guides and everything fell apart. So I highly recommend looking into this type of issue before its too late.
Old Aug 30, 2015 | 10:29 PM
RD1's Avatar
RD1
Vehicle: 97 coupe
I have same problem on my drivers side window too
