I've been searching the site for the last 3 hours looking for something that would tell me what kind of bulbs are in the instrument cluster.
I'm guessing that they are T5's or something of the same fitment, but am unsure. Does anyone know or have access to somewhere to find out? Thanks. |
If i remember correctly there are two 194 and three or four 73/74 bulbs.
My order from superbrightleds to replace those bulbs was this below. I think there are a couple of extra bulbs ordered. Quantity: 3 Product: T1.5-x Instrument LED bulb $ 1.79 (each) Options: Red T1.5-R Quantity: 4 Product: WLED-x5 LED Wide Angle LED bulb $ 2.99 (each) Options: Red WLED-R5 |
I searched for 2 minutes at HyundaiAftermarket.org and I found a half dozen posts saying they "think" the bulbs are 194. That sounds correct, go with it.
I believe there are four 194 bulbs, and two 74 bulbs, I remember seeing that somewhere, don't know if there is more than those bulbs. But I think you need at least those ones.
^ i think that's right, sorry i had my numbers reversed.
The bulbs are all 194 and 74 bulbs. The sizes that will fit are 168, 194's, same base, both fit. 74 is also often called 73/74.
I just did a search for... cluster bulb In all the forums and got the following. http://www.rdtiburon.com/index.php?showtop...hl=cluster+bulb That one says it. http://www.rdtiburon.com/index.php?showtop...hl=cluster+bulb http://www.rdtiburon.com/index.php?showtop...hl=cluster+bulb http://www.rdtiburon.com/index.php?showtop...hl=cluster+bulb There are more, and other search terms will find more. I believe on HA.com many years ago me and Majin Cithonan both did a big set of posts about how many of exactly every bulb you needed in what colors. |
Hey guys, thanks.
For some reason cluster bulb never came to mind, Redz. Tried almost everything else, instrument cluster, gauge cluster, etc.... BTW Redz, the stickers came. Look great. |
