Kspec Timing Kits
Has anyone had any problems with the kspec timing kits? I thinking of ordering one if it gets good reviews. If not anyone know of a similar kit to be purchased? It has to be done very soon so need answers please.Thanks!
MAD JOHN
Timing Belt
Tension Assembly
Idle Pulley
Water Pump Assembly
Water Pump Gasket
Power Steering Belt
Water Pump Belt
A/C Belt
theromstat and gasket
crank and camshaft oil seals
Kspec
Timing Belt
Tension Assembly
Idle Pulley
Water Pump Assembly
Water Pump Gasket
Power Steering Belt
Water Pump Belt
A/C Belt
I hightlighted the extra parts
Timing Belt
Tension Assembly
Idle Pulley
Water Pump Assembly
Water Pump Gasket
Power Steering Belt
Water Pump Belt
A/C Belt
Kspec
Timing Belt
Tension Assembly
Idle Pulley
Water Pump Assembly
Water Pump Gasket
Power Steering Belt
Water Pump Belt
A/C Belt
