Idle boost
Old Nov 5, 2017 | 12:10 AM
Megladon's Avatar
Vehicle: Tiburon
Default Idle boost
Hey how is everyone doing. I have not posted in a while but here it goes. I have always had a idle problem with my 98 turbo fx. If I don't play with the throttle after 1st start the idle drops and completely shuts of vehicle. I have to repeat this process until temperatures gets warm and then I can ease off the throttle slightly and until becomes stable. Any of you boosted guys have this problem? is this common? Any help would be awesome.
Old Nov 6, 2017 | 02:02 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
What ECU are you using?
Old Nov 6, 2017 | 10:34 PM
Megladon's Avatar
Vehicle: Tiburon
megasquirt purchased from kfx I believe when it was active.
Old Nov 7, 2017 | 05:24 AM
JonGTR's Avatar
There are cold-start and high-idle settings that may not be tuned properly. I would take the ECU to a local MS tuner. Or learn how to adjust the settings yourself.
Old Nov 7, 2017 | 08:59 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
When you installed the MS, did you eliminate the IAC motor or is it still there?
Old Nov 8, 2017 | 07:27 PM
Did this problem exist before the MS was installed?
Old Nov 9, 2017 | 01:18 PM
Megladon's Avatar
Vehicle: Tiburon
Am located in the Los Angeles area. Yes I did take it to a local tuner that has megasquirt experience. No the idle issue was not an issue prior to going turbo. I do not know how to play with the tune. I am aware of tuner studio but I have not messed with it, and lastly no I did not eliminate the IAC it is still plugged in. I hope I have answered everyones question.
Old Nov 9, 2017 | 01:23 PM
JonGTR's Avatar
If the car ran fine before the MS, and had a cold start issue after, then the cold start options is most likely the problem. I would start by making sure you have a good vacuum though. Leaks can also cause all kinds of problems.
Old Nov 10, 2017 | 10:22 AM
Megladon's Avatar
Vehicle: Tiburon
Sounds good. Well am start with what I can do and that is checking vacuum. I will admit I have a shop air hose type going from the brake booster to the manifold. At the time of the build I had to do what I needed to get the car running. As far as the IAC valve is still the original. Should I replace it or eliminate it, suggestions would help narrow down this idle cold start problem.
Old Nov 11, 2017 | 08:20 PM
i8acobra's Avatar
That could be a problem. Especially if you're boosted. That hose is supposed to have a one-way valve so that the brake booster only sees vacuum. Also, if the engine stalls, you'll lose your power brakes immediately.
