Fuel Or Ignition Rev Limiter?
Old Sep 22, 2005 | 07:22 PM
t4turbotiburon's Avatar
dose anyone know if we have a fuel cut or ignition cut rev limiter?
Old Sep 22, 2005 | 09:31 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Fuel cut.
Old Sep 22, 2005 | 09:50 PM
hamhead's Avatar
Old Sep 22, 2005 | 09:54 PM
'treezy's Avatar
remove fuel cut
Old Sep 23, 2005 | 04:34 AM
I belive if we just have fuel cut and no ignition that is excellent as we can now use the greddy emanage ultimate to do away with our rev limiter. laugh.gif The new greddy ultimate is far superior to any other standalone out there even that smt6 thingy. here is some info check it out.
greddy ultimate
Old Sep 23, 2005 | 12:17 PM
'treezy's Avatar
swett, does it actually cvome with everything or do you still have to buy multiple harnesses for like 50 bucks each to get everything you want.
Old Sep 23, 2005 | 12:21 PM
Mad_john's Avatar
unless you remap it its 6800
Old Sep 24, 2005 | 05:10 AM
mad john unless you have read through the ultimate web page you wont understand how it works it extends the factory fuel map beyond the rev limiter and keeps the fuel flowing as it is intercepting the injector signals from the ecu. It will work as long as we dont have an additional ignition cut too. It has been done before with some vtec setting but was unsafe due to some reason i dont know apparently greddy has worked around this problem and made it safe. The ultimate comes with the box and the software for about 470$ street price Ebay. Then you either have to have a current greddy emange installed and use the harness there (with an additional add on harness) or buy the new harness combination for 90$ or so. If you already have the blue its perfect plugs right in and add a couple more wires and boom your done. I just hope they get all the bugs worked out in a couple of weeks wink1.gif
Old Sep 24, 2005 | 09:18 AM
Dude, use punctuation, or at least put some spaces in between seperate thoughts.
I'm not even going to bother reading that ... conglomeration of jumbled words.
