Fixed: Noisy Vibration Engine Idle
Old Nov 4, 2006 | 02:41 PM
My engine was starting to make noisy enginey sounds when idling so I changed the PCV and dropped new plugs in today.
The PCV was ONLY $3.50 at <strike>O'Rileys</strike> Autozone and it took 2.5minutes to install.
Anyways, i was starting to think I had a compression problem, turns out just needed a new PCV cuz it was clogged. Try it guys.
Old Nov 8, 2006 | 09:23 PM
Carrera's Avatar
is that the little filter we put on? i thought it was called the pVc system? guess not.... owells, so this will vix shaky idle huh? good deal ive been thinking it was a compression issue too haha.
Old Nov 8, 2006 | 09:24 PM
hamhead's Avatar
Just to enlighten me, explain to me why weak compression would result in a harsher idle.
Old Nov 10, 2006 | 07:15 PM
IronFox's Avatar
Now before you laugh at me, all the cars ive ever owned were a 73 cutlass, 84 trans am, 85 jeep, and a 87 grand am and all of them had the pcv valve right on the rocker cover case. I`m trying to change my pcv valve and cant find it. lmao.gif
EDIT: Nevermind ... found it ... I`m an idiot ...
Old Nov 10, 2006 | 09:13 PM
Um... actually I just remembered I bought everything at autozone not o'rileys that day. my bad.
Old Nov 11, 2006 | 01:51 PM
rallyman's Avatar
<div class='quotetop'>QUOTE (KAW21100 @ Nov 9 2006, 12:23 AM) <{POST_SNAPBACK}></div><div class='quotemain'>i thought it was called the pVc system? guess not....</div>
No, it is the PCV valve which stands for Positive Crankcase Ventilation.
Old Nov 11, 2006 | 02:25 PM
Screwdriver's Avatar
It's a good practice if you change it once every 20,000 odd miles, especially in rougher conditions.
Old Nov 11, 2006 | 02:35 PM
i changed mine yesterday and what a difference in engine noise
Old Nov 11, 2006 | 04:43 PM
zoned019's Avatar
Vehicle: 97 Tib
umm..
got any pics? i wanna see where it is + what you bought.
