Fixed: Extreme Deceleration
Old May 19, 2007 | 09:00 PM
<div class='quotetop'>QUOTE (rollwitstyle @ May 19 2007, 03:04 PM) <{POST_SNAPBACK}></div><div class='quotemain'>I did this today too, I also hit the iac with the contact cleaner, do I have to silicone lube it or will it be fine? by the way, the car drives mint now fing02.gif</div>
Cleaning the IAC is good. I just lubed mine because I wanted to make sure it was opening and closing properly.
Old May 21, 2007 | 07:34 PM
zoned019's Avatar
Vehicle: 97 Tib
How exactly do you lubricate the IAC?
Old May 21, 2007 | 07:46 PM
spray the high temp silicone lube into it. It makes it move (freer, freeer?) more freely.
Old May 22, 2007 | 09:53 PM
alpineboarder's Avatar
Vehicle: 1999 Hyundai Elantra
Like any high-temp silicone lube, or a specific one?
BTW, followed what was outlined, and there is a very noticeable difference. The car does not slow down as much when off the gas, and does idle more smoothly. And my catback quieted down. Maybe because the MAF is no longer under-reading? Whatever that did, I like it!
Old May 22, 2007 | 10:38 PM
You can use the lubrication of your choice. Silicone lube in general is a good high temp lubricant. It does not burn up or off easily. It was a very noticable difference between unlubed and lubed movement of the IAC.
