Exaust Smoke When Starting But Only In The Morning
Old Mar 13, 2009 | 07:38 AM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
So for the last 2 days when i start my car up in the morning i have had a good deal of blue smoke. Its only in the morning (car sitting for a while). It does not do this when i leave for work or when driving. I cant tell if anything is burning while i drive as i do not have a sense of smell. (medical cauterization inside the nose for nosebleeds kills sense of smell.) Oil level is fine, and a quick 5 - 10 seconds at 2500 rpm clears the smoke.
Im at a loss since it is not constant and only happens in the morning.
Im going to check my oil for antifreeze and check to see if there is oil in the radiator. I dont think there is becuase the car does not feel as if its losing power.
Old Mar 13, 2009 | 07:43 AM
demon_fox's Avatar
Vehicle: 2000 hyundai tiburon
seems like it would be oil seeping past your lifters while it sits for long time. nothing to worry bout just your engine gettin some wear
Old Mar 13, 2009 | 08:28 AM
1) how many miles on the engine?
2) a compression/leakdown test combination would be informative.
Old Mar 13, 2009 | 08:54 AM
well its definately oil...
first thing i would do is a compression test. although, from the sounds of the symptoms you have listed so far, i would say something to do with the head.
have someone with a sense of smell drive close behind you after its all warmed up and look for puffs of smoke, or see if they smell any oil.
just cause you can't see any smoke while your driving, doesn't mean its not there. usually the puffs are to small, and you wont see them from the drivers spot.
Old Mar 13, 2009 | 09:11 AM
Bullfrog's Avatar
Stocker - jsut shy of 90,000 miles
Compression testing soon.
Old Mar 13, 2009 | 09:31 AM
bigfishmoney's Avatar
As was mentioned before,a valve seal or some other oil leak allowing to drip overnight.
Old Mar 13, 2009 | 07:57 PM
Bullfrog's Avatar
Anyone else? Maybe something simple that was not mentioned?
Old Mar 13, 2009 | 10:25 PM
Role Reversal's Avatar
Vehicle: 05 Subaru WRX
It's deffinately leaky valve guides. Not really an easy fix, but you can just replace the head as a whole. If you do decide to fix the problem instead of replace it, you might as well get a port and polish on the head too.
Old Mar 13, 2009 | 10:56 PM
Bullfrog's Avatar
Do valve guides all wear at the same rate?
Old Mar 13, 2009 | 11:24 PM
if your are gonna replace one, you might as well replaces all of em.
