Engine sensors- Wire Colours (picture or text help)
Old May 15, 2012 | 02:24 PM
Antonyr123's Avatar
Vehicle: Hyundai Accent
Default Engine sensors- Wire Colours (picture or text help)
Hey guys, I have 5x 3Pin sensors. i was wondering if somone can just look at there sensors and tell me the colors of the wires for
Idle Valve
Crank Sensor
Knock Sensor
Cam Sensor
TPS Sensor
Problem is. All 3 Pin conectors fit the same Connectors, so once loom was striped down for StandAlone ECM the wires all got mixxed up
Old May 15, 2012 | 09:41 PM
Colors vary too much to be trustworthy IMO. Nothing but nothing beats a multimeter set to "beep" continuity test. Find all the wires in <5 minutes.
Old May 16, 2012 | 07:08 AM
Red Raspberry's Avatar
I agree about the colors. The wire diagrams for my 2010 Genesis Coupe don't match my car on certain circuits.
Old May 16, 2012 | 09:19 AM
wheel_of_steel's Avatar
+3 on that one. Was this for beta 1, 2, 2 CVVT?
Old May 16, 2012 | 12:58 PM
tib _500's Avatar
best stuff i could find is the basics man
Old May 17, 2012 | 02:30 PM
Antonyr123's Avatar
Thank you everyone.
I guess it really dont matter what wires there is.
But some of the cables are projectored by noise suppressing. im guessing thats only cam,crank and coil sensors
Old May 17, 2012 | 02:34 PM
Antonyr123's Avatar
im guessing all of the wires that run to ecm. are the sigal wires,
Cam sensor
5V > Live
Sensor > ECM/Megasquirt
GND > GND
What is best way to test sensors grounds ? on the thread or internals with a connectivity meter ?
Old May 17, 2012 | 04:44 PM
Your <5v wires are the ones with the shielding. Usually 5v in and 4.5-0.5v out. But yes the sensors. crank, cam, TPS, EGR, depends on what there is.
Old Jun 27, 2012 | 07:48 AM
Antonyr123's Avatar
so is there away i can tell what the sensor Pins are ? GND/Sensor/Power
Old Jun 27, 2012 | 07:49 AM
You can look at the Hyundai wire diagram. It gives you the wire colors and pin orientation.
