Electrical Problems? Fuse Information Here
<span style="font-size:14pt;line-height:100%"> Driver's Floorboard FuseBox </span>
Fuse - Amperages - Circuit
1- 10A - Instrument cluster
2 - 15A - Power door locks
3 - 15A - Stop lamps, Ignition key lock
4 - 10A - Hazard warning
5 - 30A - Rear glass defogger
6 - 15A - Room lamp, Clock, Door lamps, Luggage room lamp
7 - 15A - Rear wiper And Washer
8 - 15A - Front wiper, ETACS,Vehicle speed sensor
9 - 10A - Back-up lamps, TCM, ECM, A/T, interlock, ETACS
10 - 10A - Instrument cluster
11 - 10A - ABS
12 - 15A - Air bag
13 - 15A - Cigarette lighter, Power door mirrors, Instrument cluster
14 - 10A - Audio, A/T shift and key lock control
15 - 10A - EPS, Sunroof, O/D switch
16 - 10A - Cruise, Head lamps, Fog lamps power window, Blower controls, DRL
17 - Not used
<span style="font-size:14pt;line-height:100%"> Engine Bay FuseBox</span>
Description _-_ Amperages _-_ Circuit protected
Fusible link
A (Dark blue) _-_ 100A _-_ Generator
B (Blue) _-_ 20A _-_ Engine control relay, Fuel pump relay
C (Pink) _-_ 30A _-_ Power windows
D (Blue) _-_ 20A _-_ A/C condenser fan control
E (Red) _-_ 50A _-_ Battery power source
F (Green) _-_ 40A _-_ Head lamps, Tail lamps
G (Pink) _-_ 30A _-_ Radiator fan control
H (Pink) _-_ 30A _-_ ABS control
I (Pink) _-_ 30A _-_ ABS control
J (Pink) _-_ 30A _-_ Ignition power source
K (Pink) _-_ 30A _-_ Blower control
Fuse
A/C _-_ 10A _-_ A/C condition control
HORN _-_ 10A _-_ Horn
B/ALARM _-_ 10A _-_ Audio, TCM, ECM
LEFT LAMP (LH) _-_ 10A _-_ Left tail lamps
RIGHT LAMP (RH) _-_ 10A _-_ Right tail lamps
FRONT FOG LAMP _-_ 15A _-_ Front fog lamps
H/LAMP (LOW) _-_ 10A _-_ Head lamps
G/LAMP (HIGH) _-_ 15A _-_ Head lamps
Power connector
L _-_ Fuse 3 _-_ (15A), TCM, Audio Fuse (10A)
M _-_ Fuse 14 _-_ (10A)
<span style="font-size:14pt;line-height:100%">Drivers Floorboard Relay Board</span>
11 - 10A - ABS
12 - 15A - Air bag
17 - Not used
Fusible link
Fuse
Power connector
