Egr Valve...
Old Oct 2, 2006 | 10:03 AM
lukeyn's Avatar
Has anyone had experience with their Egr Valve sticking open>? and does this have any other name???
Old Oct 2, 2006 | 10:06 AM
'treezy's Avatar
Exhaust Gas Relief Valve, I'm not familiar with Hyundai's (I thought we just had EVAP cannisters) rather Chevy's... rolleyes.gif
They stick, sometimes it's the pintle sometimes it's the valve. Sometimes the OBDII code will say a faulty EGR and all it is is a faulty circuit between the EGR and the TPS, or VCM (in Hyundai's case the ECU), or like my car just recently it's just the pintle position circuit that's faulty. (causes major problems due to the VCM's natural habit to go into limp-in mode).
Old Oct 2, 2006 | 10:10 AM
um from what ive seen we dont have EGR
lol
Old Oct 2, 2006 | 10:54 AM
Rare Rolla's Avatar
EGR could mean Exhaust Gas Recirculation valve in which case it is just a connection from the headers to the intake with a valve that controls the flow. This is used to raise the air temperature of the intake air and raise the pressure to help with efficiency and gas mileage. Usually this valve works opposite from the throttle (closing at full throttle so you get cooler more dense air for power, and opening at cruising speeds to give you better gas mileage). I'm still new to hyundai's and havent spent much time under the hood of one so i'm not sure which EGR we have. If we have evap canisters then the EGR probably stands for exhaust gas recirculation.
Old Oct 2, 2006 | 11:40 AM
^^ we dont have a EGR man
Old Oct 2, 2006 | 11:51 AM
lukeyn's Avatar
alrightwell the guy at autozone hooked up his code reader because my cel was on, and it said that the egr valve was faulty??
Old Oct 2, 2006 | 12:16 PM
what was the EXACT code
he probably wasnt knowin what hes talkin about
Old Oct 2, 2006 | 12:18 PM
lukeyn's Avatar
i dont know, i;ll go uptown here in a little bit to find out
Old Oct 2, 2006 | 12:42 PM
i'm having some serious problems with my purge solenoid. is this what you guys are talking about?
and Exhaust Gas Recirculation could be those two tubes next to the battery tray, one for intake and the other for purge, no?
Old Oct 2, 2006 | 12:48 PM
^^ if that were true then we would need a tube from the exhaust to the intake
which we dont have...
