Diagram needed !
I was wondering if anyone happen to have an 04 gk cluster diagram handy or can point me to the right place...
I have one from all data but the pins seem to be completely wrong!! Thanks! |
All Data uses the factory diagrams. You sure you're reading it correctly? The diagram could be harness side or connector side. Also, be sure you have the right connector number. Also, make sure you picked the correct engine when looking up the diagram. You looking for a 4 cylinder or V6? I have access to All Data.
Yeah. I picked it for v6 but the pins from the diagram and the pins to the back of the cluster don't match at all..
The numbers are off. |
And if you have accesses to all data you'll see the diagram I'm talking about when I try for other years I can't find it...
I had a teacher that was a hyundai tech and found a good diagram but I didn't have him print it out sadly.. And I can't get it now.. It's strange.. |
So you're looking for an '04 V6 cluster diagram?
heres one from mitchell if that helps...
http://imgur.com/a/VJzOt theres a service manual here -> http://www.newtonnet.co.uk/coupe/#Service_Manual it says 05 and newer but might help, who knows |
Those didn't really help I need one to tell me which wire is what on the back of the cluster.
And yeah 04 gk |
Nice! Thankyou!!
