Checking Alternator
Old Nov 22, 2005 | 02:52 PM
deestibo's Avatar
wondering if there is way to check the alternator without taking it out?
Old Nov 22, 2005 | 03:01 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
yes, it's easy.
start the engine and measure voltage on the battery. it should be about 14V (not lower 13.5, not higher than 15V). then turn on lowbeam, highbeam, blower, some other accesory, voltage shouldn't be changed much.
be sure that your battery is not discharged.
Old Nov 22, 2005 | 03:12 PM
deestibo's Avatar
what do you mean not discharged
Old Nov 22, 2005 | 03:17 PM
KayJai's Avatar
As in besure your battery is FULLY CHarged
Old Nov 22, 2005 | 07:08 PM
deestibo's Avatar
how many volts should the alternator give out the 14.5 volts
Old Nov 22, 2005 | 07:42 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
before starting your car, loosen your terminal bolts. start your car then take off the terminals...
the car should stay running
Old Nov 23, 2005 | 02:00 AM
Dmitry's Avatar
that's not a very good idea to taking off terminals from battery, while car is running.
14.5 V is ok.
Old Nov 23, 2005 | 08:42 PM
Tibs's Avatar
Taking the battery terminals off while the car is running is a good way to burn up some control modules. The battery acts as a buffer eliminating voltage spikes.
