brake master cylinder brace and 1" upgrade
Vehicle: 2000/Hyundai/Coupe F2 Evo
has anyone made a brace to stop any movement the master cylinder makes when braking? If so did you feel much benefit?
also i read a post on here about fitting a 1" master cylinder as an upgrade, what model is that from and was it a direct fit? I've got a GK master cylinder which is bigger than the std RD unit but the fitting for the servo is different so not really a goer.
Unless you've already got braided steel lines and twin-pot calipers, I'd put this in the "why bother" category of mods. If you can lock up the front wheels, you have enough brakes. If you don't like the feel, it's easier to change the flexible lines or pads, than to figure out (and then implement) how to reinforce the MC.
i kinda agree with you, just wasn't sure if it would improve pedal feel rather than out and out braking performance. I know on some cars you can buy an off the shelf kit for bracing the mc's.
On some cars, the brakes push through the floor, vs. the firewall. On some cars, the brakes are all drums. Hell on some cars they don't have brakes just electric motors run backwards.
Do what makes sense for your car. This mostly doesn't IMO.
