2001 tiburon vibration
Old Jun 14, 2015 | 12:11 AM
Split911's Avatar
Default 2001 tiburon vibration
My 2001 tiburon 5 speed manual vibrates/hum at 3000 rpm in every gear and only when in gear
Old Jun 14, 2015 | 03:16 PM
2000J25SP's Avatar
Vehicle: 2000 Hyundai Elantra GLS
Don't drive your 2001 Tiburon at 3000rpm... problem fixed.
Old Jun 14, 2015 | 03:37 PM
We need more info. Is there a vibration in the steering wheel? What mods do you have done to the car? If you have a video or sound clip, even better. But your post is extremely vague and would be near impossible to diagnose without more info.
Old Jun 14, 2015 | 10:15 PM
If it's only when in gear, it's something in the drivetrain past the flywheel/flexplate. If it happens only at one engine speed regardless of road speed, it's between the flywheel/flexplate and the end of the input shaft. That leaves clutch/torque converter, throwout bearing, transaxle input bearing, input shaft, and gears.
Unless I've missed something. Sorry to say, this sounds like a hassle.
Old Jun 16, 2015 | 01:23 PM
Cereal Killer's Avatar
Vehicle: 2005 V6 Tib
You need an extra jiggawatt for your flux capacitor.
Old Jun 16, 2015 | 01:39 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
+1 on what Stocker said.
Old Jun 19, 2015 | 07:36 AM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
If its just at a certain engine speed check your motor mounts. Are you running stock or aftermarket pullies?
