150,000 mile tune up
I just hit 150K in my tiburon and I was wondering if I should do anything specifically for a tune up? I changed my timing belt at 120K, did new plugs, wires, fuel filter at 140K, got a new AEM air filter for AEM CAI 5k ago, got new tires on the car, and just did an oil change 2 weeks ago. Am I ok or do you guys think I should do something else? What about seafoam?
add seafoam to clean injeectors and fuel lines by putting in gas tank
add seafoam to clean oil thats burnt inside engine including the (im sure u already know) cylinder head and valve train by;
add to the "add oil" location on top of Hyundai's engine to clean engines internal components as well
I would also remove the air intake, and lubricate the throttle body n throttle
and when changing brake pads re-lubricate brake assemblies pins, (2 on each wheels brake system)
Also consider doing the big 3 wire upgrade as i provided a link for u
Good luck
Good luck
