Daytime running lights for 2017 Sonata base swdan
Newbie here. I have a 2017 and a 2016 base model Sonata. Is there an aftermarket daytime running light kit that will fit these without modifying anything? The only ones I can find say they fit SE models only. Thanks |
Are you looking for something different than this sort of thing? (on top of the page)
https://www.carid.com/2017-hyundai-s...er=1&sub-model[ourSubModelName][]=Base Are you just trying to add the lights to your car? Is the wiring installed in your car already and there are just no lights? I don't know how they made the wiring looms. If the wiring is there, you may be able to plug right into it, or you may need to add relays, fuses, etc to complete the system. If you are only finding kits for cars that already have the lights installed, that may be because nobody makes a kit that duplicates factory-installed wiring/switches/etc. It could also be that the bumper covers are completely different (again, I'm not sure) in which case a kit would include an entire bumper which is going to be much more expensive than just some lamp assemblies! If that is the case you may need to talk to a body shop or junkyard (or dealership) to get all the required parts |
