Hyundai Sonata Forum The Hyundai Sonata Forum. The Sonata (around since 1989) and Hyundai XG300/XG350 (new for 2002) pickup the near-luxury segment for Hyundai. Find out where to get all the luxuries Korea is holding back on (HID, navigation systems, etc.) and how to tune your Hyundai Sonata, Azera, or XG for performance.
20's on 08 hyundai sonata ?
Old May 9, 2010 | 11:38 AM
shenbanjo's Avatar
Vehicle: 2008/hyundai/sonata
Default 20's on 08 hyundai sonata ?
Hi eveyone,.. jus curious to know if 20 inch rims will fit on an 08 hyundai sonata GLS , worried about rubbing , some websites list 19's as a max and some list 20's . Wondering if anyone has sat theirs on 20's and if any mods were needed. Thanks
Old May 9, 2010 | 01:23 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
they will fit under the fender, but if they will rub on anything... that depends on the width, tire size, offset, and the camber your willing to run to fit the rim you want.
Old May 9, 2010 | 01:37 PM
shenbanjo's Avatar
thanks,... its 225/35-20x8.5
Old May 9, 2010 | 02:04 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
They are a grand total of 2mm taller and 10mm wider than stock, so unless the offset is wrong they should be fine. You are loosing something like 40% of your sidewall and adding a good bit of unspring weight so don't expect it to ride as well ;-)
