2006 - 2010 Hyundai Sonata 3.3 V6 strut bar
I believe Ultra Racing to have quality products as well.
I believe front wheel drive cars generally understeer. To counter understeer, you have to reduce speed by lifing off the gas. Rear wheel drive cars generally oversteer. Most passenger car suspensions are designed with a certain amount of understeer if not mistaken. It is much safer and easier to correct than oversteer. Ideal suspension would be neutral setup.
To correct understeer; softer front spring rate, stiffer rear spring rate, small front sway bar,thicker rear sway bar, raise front tire pressure, lower rear tire pressure. To correct oversteer; stiffer front spring rates, softer rear springs, larger front sway bar, smaller rear sway bar, lower front tire pressure, higher rear tire pressure.
So, have you installed the Ultra Racing 30mm front bar(UR-AR30-404) and 20mm rear bar (UR-AR20-405) yet? Interested in knowing if bars installed without issue.
Follow up regarding availability of Ultra Racing front strut bar for 2006 - 2010 Hyundai Sonata with 3.3 engine. Ultra Racing has finally released one piece steel front strut bar that fits 2006 - 2010 Hyundai Sonata & 2008 - 2011 Hyundai Azera with 3.3 engine!!
http://www.nextgentuning.rpmware.com...i-2019333.aspx
All interested in purchasing Ultra Racing strut bar, can do so by visiting NextGenTuning. NextGenTuning has is willing to discount price and add free shipping for HyundaiAfterMarket members interested.
Click on the link provided and enter promo code NGT25S when checking out to receive discount and free shipping.
