Hyundai Santa Fe Forum The Hyundai Santa Fe Forum. Hyundai's Sport Utility Vehicle discussions here such as the Santa Fe, Tuscon, and Veracruz! Learn what makes these great cross overs and SUV's one of the favorites amongst Hyundai owners.
Exhaust wraps
Old Dec 11, 2002 | 12:31 AM
Lester's Avatar
Vehicle: 2011 Genesis 3.8
Default Exhaust wraps
Hi there
I'm driving a Santa Fe V6 2.7L AWD. I'm thinking of wrapping my headers to bring out the heat. Wat do you guys think?
Regards
Lester
Old Dec 11, 2002 | 12:51 AM
turbulence's Avatar
that's not a bad idea.
1) it keeps the heat out of the engine bay, which helps if you have a cai.
2) it keeps the heat in the exhaust gas flow, which helps maintain its velocity. this also helps if you get an cat-back.
if you get a cai, wrap that, too.
Old Dec 11, 2002 | 10:51 AM
Bringrice's Avatar
Cons -
1.) Keeping all that heat trapped inside your headers will speed up the corosion process and you will eventually have to replace them quicker than without the wrap
2.) Looks gay
Old Dec 12, 2002 | 03:12 AM
Do NOT do this on stock exhaust manifolds.
Stock exhaust manifolds are made of Cast Iron. They cannot withstand the additional heat/cooling that happens when you use exhaust wrap. Your cast iron manifolds will crack VERY quickly.
I would reccomend you heat wrap your CAI/Intake, and then wrap over the heat wrap with Heat Reflective wrapping.
Old Dec 12, 2002 | 07:47 AM
tibby01's Avatar
Vehicle: 2001 Tiburon
If you decide to wrap them, check out summitracing.com thats the cheapest place I found to buy the wrap you would need.
