Hyundai Santa Fe Forum The Hyundai Santa Fe Forum. Hyundai's Sport Utility Vehicle discussions here such as the Santa Fe, Tuscon, and Veracruz! Learn what makes these great cross overs and SUV's one of the favorites amongst Hyundai owners.
2.4 santa fe engine
Old Nov 4, 2002 | 06:39 AM
accent 1's Avatar
Default 2.4 santa fe engine
is this engine similar to the tibby 2.0?
Old Nov 4, 2002 | 06:46 AM
JAWS 021's Avatar
No
2 different blocks
trannies
ecu's
Suspension
A whole different car.... i know what your thinking about buddy... and it will cost a lot
In the long run its really not worth it... frown
Old Nov 4, 2002 | 09:59 AM
SPIKE's Avatar
Old Nov 4, 2002 | 10:03 AM
Go through the trouble of an engine swap for 2-3 HP and 17 Ft lbs of torque?
No into a tibby or elantra Into an accent maybe, then it might be worth it.
Old Nov 4, 2002 | 08:23 PM
accent 1's Avatar
so Random there are no similarities between the 2.0 and 2.4?
Makes me like my neon even more the big swap for the neons is the 2.4 block from the stratus!
Use the 2.4 block the 2.0 head and all the goodies for the 2.0 still work!!!!
The benifit is more displacement better bottom end power!
Old Nov 5, 2002 | 01:28 AM
The 2.4L in the Santa Fe is the same 2.4L that is used in the I4 sonta. It is not a Beta or an Alpha motor. (I can't remember the designation on that motor.)
For the accent, the best bet is to use a beta motor or the Sonata/Santa Fe I4...if you can get it to fit!
