Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
BETA 2 Engines
Old 01-08-2010, 11:34 PM
Schwitzer Turbo's Avatar
Vehicle: 1995 Scoupe Turbo GTR
Default BETA 2 Engines
Hi all, i would like to find out some info regarding this engine.
as per wikipedia
<div class='quotetop'>QUOTE </div><div class='quotemain'>Beta II
During 2001-2002, the new Beta II engine made its debut in models such as the XD Elantra and GK Tiburon. Output is 138 hp (102 kW) at 6000 rpm with 136 foot-pounds force (184 N·m) of torque (184 N·m) at 4500 rpm. It has a cast iron engine block and aluminum DOHC cylinder heads. The latest version of the 2.0L Beta engine (G4GC) features CVVT, which exists only on the intake side, a first for Hyundai/Kia. The following changes were noted.</div>
i have never seen a BETA 2 Engine, how would i distinguish between a BETA 2 and a Beta 2 with CCVT?
Hyundai use's the following engine codes for ther beta's 1.6= G4GR 1.8= G4GM 2.0=G4GF BETA 2 2001-2002 2.0=? and beta 2 with ccvt=G4GC but none of these numbers appear on the block?
these are the 2.0 engine i have seen.
the J2 2.0 (im Guessing this is the J2 Series Elantra here is a pic of the J2.1.6
then there is this engine the XD 2.0 from what motor does this car come out of ? is it a Beta 2 ? it had no tappet cover so it look very similar to the beta 1 or is it out of something other than a elantra ? will a Tuscons 2.0 use the Identical engine to a Tiburon 2.0 or elantra 2.0?
so if anyone has seen there Engine block on the elantra please let me what it says...
THANKS
Old 01-09-2010, 12:49 AM
rooney10's Avatar
Vehicle: 2002 Hyundai Accent GS
Lets a good question. I know I got my engine (BetaII non-ccvt) I have now in my Accent from a 04 Elantra. Hmmm...I shall check that out in the morning.
Old 01-09-2010, 01:56 AM
<div class='quotetop'>QUOTE (rooney10 @ Jan 9 2010, 09:49 AM) <{POST_SNAPBACK}></div><div class='quotemain'>Lets a good question. I know I got my engine (BetaII non-ccvt) I have now in my Accent from a 04 Elantra. Hmmm...I shall check that out in the morning.</div>
thanks rooney please let me know!
Old 01-11-2010, 10:22 AM
Bommello's Avatar
IIRC it has CVVT if you see a sensor coming out of the nub that sticks out on the top drivers side of the motor .
Old 01-12-2010, 09:12 AM
rooney10's Avatar
Alright. I have the XD20 block. A 2004 Hyundai Elantra engine.
Old 01-19-2010, 11:22 PM
what does the stamp RD18 mean? it comes out of a sonota?
Old 01-21-2010, 09:02 AM
rooney10's Avatar
I am not sure but you can try out http://www.hmaservice.com/ for the answer.
Old 01-23-2010, 11:48 PM
<div class='quotetop'>QUOTE (rooney10 @ Jan 12 2010, 06:12 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Alright. I have the XD20 block. A 2004 Hyundai Elantra engine.</div>
does the xd20 also have forged steel connecting rods? (go to wikipedia and search hyundai beta engines)
Old 11-26-2010, 11:39 PM
fjimenez88's Avatar
Vehicle: 2000 Hyundai Accent
xd20 blocks are beta engines, beta 1 uses black top cover(sparks cover), beta 2 uses grey top cover(sparks cover) also in the front right corner it say non-cvvt or cvvt, a simplest way to know is looking if it uses airflow or map (talking about xd20 only) beta 2 non.cvvt uses map, beta 2 cvvt uses airflow, dont get confued with the airflow of j2 that is not beta engine. airflow of beta 2 cvvt engines has airflow meter and ITS(intake temp sensor) inside itself, j2 uses airflow meter and in the intake uses ITS apart
i had J2, xd beta 1, beta 2 and beta 2 cvvt so i know many differences
Old 05-03-2011, 03:33 AM
Onijin's Avatar
Vehicle: 2008 Hyundai i30
It would've come out of a RD Coupe/Tiburon and would've indicated the 1.8L base engine, as opposed to the 2.0L option which would've been stamped as RD20. Either way, it's a Beta I engine, whereas the XD Elantra's and next generation Tiburon/Tuscani would've had the Beta II's. Safe bet is that anything 2001 onwards would've had the Beta II engine.
Speaking of the Wikipedia entry, I was the person who put up the info on that page many years ago, which was a copy and paste job from a page I found with all the changes from the previous Beta engine (was referenced to satisfy the Wikipedia standards). If anyone can find similar documented changes with the CVVT version, feel free to add to that page as such.
Quick Reply: BETA 2 Engines
