Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Jsharptooth91's Beta 2 swap
Old Aug 1, 2008 | 08:41 AM
  #21
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
No updates at the moment. I'm on vacation in Vermont right now. I will have an update when I get back! I did do some work before I left.
Cheers..
Old Aug 9, 2008 | 10:45 PM
  #22
Updates...
I put the motor back in and here are some shots. I still have some work to do on it. But, here are some pix of what she looks like.
It's level....
Old Sep 6, 2008 | 09:34 PM
  #23
slyderdai's Avatar
I am getting ready to this swap 01 accent and an 03 beta II motor. Do you have an ecu wiring diagram? I can't find a whole lot of info on the swap also some of the links for your pics are broken.
Old Sep 7, 2008 | 12:07 PM
  #24
I will post up what I have in a while, but i don't have the car running so use it at your own risk. It should work but you never know.
You don't have to do much to the ecu in terms of re wiring.
Do you have 1.5 or 1.6?
Old Sep 7, 2008 | 08:14 PM
  #25
<div class='quotetop'>QUOTE(slyderdai @ Sep 6 2008, 08:34 PM) </div><div class='quotemain'>I am getting ready to this swap 01 accent and an 03 beta II motor. Do you have an ecu wiring diagram? I can't find a whole lot of info on the swap also some of the links for your pics are broken.</div>
Check this out:
LC Accent ECU Pinouts
Old Sep 8, 2008 | 08:49 PM
  #26
slyderdai's Avatar
it's the 1.5 sohc 5spd. I have sourced a 1.6 ecu and I'll probably just order the ecu adapter kit from SFR. I'm not to good at wiring (but I know people who are) I'd rather do metal fab work and body work.
Old Sep 8, 2008 | 10:46 PM
  #27
Dont get the adapter. Another member for HP cannot get the dam thing to work correctly. I am going to do what Japkos did, which was solder a chip from the 2.0 onto the 1.6 and be dont with it. I'm okay with electronics so that would work for me. hopeful I get my header with in the next month. I might need a welding job 187....
The only wiring you need to change is MAF to MAP. Then extend a couple of wires and that it. Perty simple..I will hope to do a good write up on it. If you have any question fill free to post up..
slyderdai where at in the world do you live?
Old Sep 8, 2008 | 11:17 PM
  #28
Well, it's a long drive to your place so I might make you buy me a 6 pack of beer to drive my welder down there. smile.gif
Old Sep 9, 2008 | 10:19 AM
  #29
Old Sep 9, 2008 | 10:25 AM
  #30
<div class='quotetop'>QUOTE(slyderdai @ Sep 6 2008, 10:34 PM) </div><div class='quotemain'>I am getting ready to this swap 01 accent and an 03 beta II motor. Do you have an ecu wiring diagram? I can't find a whole lot of info on the swap also some of the links for your pics are broken.</div>
This is the best diagram i have. Here is a link to it as well http://i237.photobucket.com/albums/ff161/j...CM/E2D0012E.gif
