Jsharptooth91's Beta 2 swap
Vehicle: 1997 Elantra(Dead project) 1986 Golf(Track whore) 2000 Ranger(Daily)
Yeah, I dont have an issue helping weld it up again. Now I kinda wish I held on to that 2.0 ecu.. she doesn't need it..
Your welcome btw.
Your welcome btw.
i believe the pinouts on the ECUs are different. i am 100% sure that if you have the 1.5 (i think you do, no ?) that you'd need to have it rewired for the 2.0 ECU to work.
<div class='quotetop'>QUOTE(ereeves116 @ Nov 13 2008, 08:44 PM) </div><div class='quotemain'>i believe the pinouts on the ECUs are different. i am 100% sure that if you have the 1.5 (i think you do, no ?) that you'd need to have it rewired for the 2.0 ECU to work.</div>
Truth to use the 2.0 ECU you either have to swap the entire harness or (as someone on HP says) desolder and resolder the chips inside and swap.
Vehicle: 2002 Accent 2.0L
<div class='quotetop'>QUOTE</div><div class='quotemain'> He's running the 1.6l ECU (was originally a 1.5l) and he plans on trying the desolder/resolder method. </div>Yes that is right about the chip.
<div class='quotetop'>QUOTE</div><div class='quotemain'> Yeah, I dont have an issue helping weld it up again. Now I kinda wish I held on to that 2.0 ecu.. she doesn't need it..
Your welcome btw.</div>
I thought I said thanks, guess not. You did an awesome job. Thanks
japako's was the one who swapped a beta chip in the the alpha ecu,
and he's giving that to me in exchange for the sfr adapter which is a pos and never worked..
he said the swapped chipped ecu transformed the car, it had mounds of low and mid range torque, chirping the heavy 17's from 1st-2nd
no empty spots like the 1.6L where the power is at the high revs..the swapped ecu gives such a smooth consistent power curve
the swapped ecu makes the beta LC pull like hell..enough to eat a 07 civic si
more good new's is, you can run it on alpha engine hardware, alpha coil packs and crank sensor, since the ecu is a alpha with a beta chip in it
which is good new's for beta lc owner's running on crappy stock 1.6L chip
so get a beta ecu, unsolder the "si chip" and put it in place of the alpha chip in the ecu, much better upgrade than a turbo..and for $90 on a beta ecuform the junker, why go turbo?
i say this is the next evolution in beta swap history
<div class='quotetop'>QUOTE(jsharptooth91 @ Nov 13 2008, 10:01 PM) </div><div class='quotemain'>I thought I said thanks, guess not. You did an awesome job. Thanks</div>
Oh no no, you did. I was just saying your welcome. Lol!
I have a question for you (or anyone that can help me) Either I am blind or it's not there. The Purge valve on the back of the beta Intake manifold??? I don't remember taking such a thing off of the alpha is it needed? IAT sensor? Where the hell is it? again I don't remember it there on the alpha (MAF) not needed maybe again? and in your pics on the front of the motor near the crank sensor you have a valve solenoid looking thing WTF is it for?
