Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Engine and tranny swap suggestion...
Old Jun 5, 2002 | 11:42 AM
traku's Avatar
Default Engine and tranny swap suggestion...
I am currently driving a 95 Elantra and I need a suggestion on what kind of engine to drop in my car. I want to get the best (most power) i can fit in there without having to make too many modifications to the bay. I also would like to turbo or super charge it, whichever is best, and to drop a standard tranny in it. Thanks in advance for your help.
Old Jun 5, 2002 | 05:25 PM
BTW...moving to ENGINE forum.
Since you have the 95 Elantra, you actually have a Mitsubishi motor in there. You should be able to drop in the Mitsubishi 4G63 turbo charged motor. You would need the stronger tranny/stronger clutch/different gear ratio's from the turbo car as well.
You can also try to upgrade your N/A motor to the turbo motor's specs.
So it really all depends on your budget and timeline.
Old Jun 5, 2002 | 05:27 PM
Shadohh's Avatar
Most of the DSM guys do the mitsu engine swap.
its usually cheaper
also you will have a turbo ecu, and they are to EASIER to deal with once you start turning up the boost.
