Beta2 internal mods help !
heres what i have, 2.0L beta2 with cvvt, can i still run the 1.8L cam mod ? and also i wanna drop in some 1.8L pistons can i use 91 octane gas ??? how much power could i expect to gain from raising the compression ?
extra info...
(motor from a 2004 elantra)
(going in 2000 accent LC with 1.5L trans)
(gonna be using 1.6L ECU)
extra info...
the cam you have in there is damn near exactly the same as the 1.8 cam so dont bother plus i actually think the cam has to be a cvvt cam (could be wrong i havent opened up any cvvt motors yet...)
the bump in compression isnt gonna help too much man, id save your money and just get a nitrous kit and have alot more power
i dont wanna run nitrous at all ! and for the cam, i think cvvt i just on the exhaust tho ? and increasing the compression to 11.0-1 should make a difference shouldnt it ?
yes cuz they will just drop in without any machine work right?
how are you going to press them off and on? its not like they bolt on or something
do you have a ring file?
do you have a ring compressor?
