Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
99 aceent beta motor and trans swap help
Old Sep 14, 2014 | 08:18 AM
that_fluffy_kid's Avatar
Vehicle: 1999 hyundai accent gsi
I know what your talking about but dont remember the name of it.
Old Sep 14, 2014 | 10:51 AM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
If you are going to use a Beta tranny, you have to use that part from a 2000-2005 Accent with an automatic tranny to fit your stock axles.
Old Sep 14, 2014 | 05:39 PM
Awesome thanks man ive been looking all over for info about the axles.
Old Sep 16, 2014 | 04:57 PM
SCAccent's Avatar
Vehicle: 02 Accent
I'm using a beta 1 engine and tranny in my accent. And I'm using an alpine turbo kit for it.
Old Oct 3, 2014 | 03:40 PM
SCAccent how much boost do you run ?
Old Jan 21, 2015 | 11:30 AM
jordanaccentgs's Avatar
Vehicle: 2001 Hyundai Accent
Im 80% sure for the passenger side mount on the x3 you can use the beta 2 engine mount and drill a second spot for it on the bracket side to avoid making a custom mount yourself. I cant remember what years that worked for exactly though.
Using the alpha tranny is the easiest but since your tranny is in need of rebuild i would consider going for the beta tranny especially if you have any plans to boost. You will need to slot engine mounts and get axles to compensate for the tranny and engine shift. You can grab both axles from the 02 accent automatic they have the right dimensions and the lock rings are in the right place.
