Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
4G63T Swap - I know already...
Old 05-11-2003, 01:29 PM
Anthony Thomas's Avatar
Default 4G63T Swap - I know already...
I'm not going to ask if it can be done, I've seen it done, I know it's possible and in fact rather easy.
What I wanted to know, would it be easier IF you use the DSM harness the same year as your Elantra or would it be easier to use a harness from a '89 Mirage GT turbo?
I found a '92 Elantra with a bad automatic for $450, I was thinking about picking this up and since I would want to swap the automatic out for a 5 speed, I might as well do the rest of it, put the DSM harness in, ECU and turbo transmission also. Would I need the shift linkage from the DSM or from a 5 speed Elantra?
I'm trying to make this as painless as possible and I want to complete it in 2 1/2 days with two to three people working at the same time.
I've narrowed it down to this and doing a Mazda 323 hybrid with the Mercury Capri XR2 drivetrain.
A distant 3rd is a '91 Escort GT with a cracked cylinder head. Was thinking about a GTX swap, but need to figure out how to smog it.
[ May 11, 2003, 08:30 PM: Message edited by: Anthony Thomas ]
Old 05-11-2003, 05:08 PM
The swap is rather easy in the right year elantra. (90-95).
I would suggest the mitsu wiring harness, sensors and ECU. Especially if you are going 4G63T.
You should be able to do the swap over a long weekend. The wiring is going to be the worst of it. If you want to cheat, try to re-use the elantra harness if you are staying N/A. If it doesn't work, do the basics of "air/Fuel/Spark" tests to figure out why you can't get it started. Then work on the proper wiring subsystem to get the system working.
Old 05-13-2003, 03:02 PM
If I go this route, wanna help? Your only like 35 mins from me anyway... lol
<div class='quotetop'>QUOTE</div><div class='quotemain'>Random:
You should be able to do the swap over a long weekend. The wiring is going to be the worst of it. If you want to cheat, try to re-use the elantra harness if you are staying N/A. If it doesn't work, do the basics of "air/Fuel/Spark" tests to figure out why you can't get it started. Then work on the proper wiring subsystem to get the system working.</div>
