2009/2010 Genesis Coupe Specs
GENESIS COUPE SPECIFICATIONS
-- Configuration: Front engine, rear-wheel drive -- Wheelbase: 2820 mm / 111.0 inches -- Overall length: 4630 mm / 182.3 inches -- Overall width: 1865 mm / 73.4 inches -- Overall height: 1380 mm / 54.3 inches -- Wheels: 18-inch or 19-inch five-spoke -- Engine types: 3.8-liter V6 or 2.0-liter 4-cylinder turbo -- Est. horsepower V6: 306 @ 6,000 rpm (regular fuel) -- Est. horsepower V6: 310 @ 6,000 rpm (premium fuel) -- Est. torque V6: 263 lb. ft. @ 4,700 rpm (regular and premium fuel) -- Est. horsepower 2.0t: 212 @ 6,000 rpm (regular fuel) -- Est. horsepower 2.0t: 223 @ 6,000 rpm (premium fuel) -- Est. torque 2.0t: 217 lb. ft. @ 2,500 rpm (regular and premium fuel) -- Block & head materials: aluminum for both engines -- Valvetrain: DOHC for both engines -- Valve timing: continuously variable valve timing for both engines (Dual for 2.0t) -- Estimated 0-60 mph V6: under 6 seconds -- Transmission types: 6-speed manual, 5-speed automatic (4-cylinder) or 6-speed manual, 6-speed automatic (V6) -- Front brakes: 12.6-inch (standard) 13.4-inch (Brembo package) -- Rear brakes: 12.4-inch (standard) 13.0-inch (Brembo package) -- Front calipers: single piston floating (standard), monobloc four-piston (Brembo package) -- Rear calipers: single piston floating (standard) monobloc four-piston (Brembo package) -- Limited slip differential (Optional) -- Est. top speed: 149 mph (V6), 137 mph (2.0t) -- Base curb weight: 3549 lbs. (V6); 3439 lbs. (4-cylinder) |
| All times are GMT -6. The time now is 12:13 AM. |
