Seized caliper
Anyway to fix a seized up caliper? Had to buy 2 new ones for the front and kept the old ones laying around. One of them has a seized up piston. If I can fix it, I'll keep them as spares or maybe even sell.
Originally Posted by Elantra66
(Post 702154)
You can soak it in WD40, but if it's seized, the bore is usually damaged. |
WD-40 is a water-displacing lubricant oil. To separate seized parts, use a penetrating oil instead, or a nasty petroleum-based solvent (depending whether it's rusted or gummed up). I'd say soak in penetrating oil for a week (not like you're in a hurry right), tapping hard with a mallet a few times every day after work. Then try to separate the parts.
I'm betting there will be pitting or worse, and it will have been a learning exercise but without a new set of pistons (at least) there are good odds the calipers are toast. |
