turbo beta fuel help?
okay so im finally starting my beta build the right way and i need some help on what fuel rail to use what injectors if im using an apei avc-r its pointless to use a FMU right? anyinput is great im trying to get my head back into the hyundai zone :D
need more info. Like horsepower goals, fuel pump, current injectors, etc.
stock fuel rail should be fine up to a pretty high horsepower amount, and even then you can just get a secondary injector rail and run 2 stock rails.
for injectors a mild build you could use the ever popular 440's, they are green top mustang injectors you can get them pretty cheap. fuel pump, get either a 190 or you could do a dsm pump swap... that'd be alright with the above, but if youre wanting more you can get a 255 |
i kind of posted that while i was deciding. I am thinking about this the green top 440s stock rail 255 lph walbro fuel pump aeromotive fmu tuned a smt6 im trying to make 300whp on a t3/t4 with either stock internals with the turbo headgasket or the 1.8 pistons and rods running maybe like 15-18psi? sounds doable?
