Shaved Accent
heres a mod i just did bout 2 weeks ago........ http://sphotos.ak.fbcdn.net/hphotos-..._4156851_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._4632261_n.jpg http://sphotos.ak.fbcdn.net/hphotos-..._3985759_n.jpg |
Nice! What kit and what size poppers did you use?
Hope you're installing a fail safe switch somewhere also, in case your battery or remotes go dead. smile.gif |
It was an AVS universal kit. http://sphotos.ak.fbcdn.net/hphotos-..._2128487_n.jpg Heres the company that i got the kit from, http://www.suicidedoors.com/ . Fail safe isnt ran yet but it will be soon. just got the driver side primed today. The kits instructions where decent. I had to take the doors off to run the wires. All in all it was fairly easy install.
http://sphotos.ak.fbcdn.net/hphotos-..._4561962_n.jpg http://sphotos.ak.fbcdn.net/hphotos-..._7590596_n.jpg When i was tack welding the sheet metal into place or from the grinding, I warped the door panel and had to use a lil bit more body fill then I would have liked to. I have more to do on the doors and there ws bare metal showing and wanted to get it covered because it started to gather some kind of rust residue. Ive done a lil wet sanding on the passenger side Does any one know what that reflective paint/vinyl/sticker that they use on the police cars?? Where the body molding used to be i didnt realize that there was holes with clips that held it on. So i used some aluminum tape roughed it up a bit hit it with some fiber filler, body filler, then primed. beercheers.gif thanks.gif |
where at in kansas?
im in wamego |
that is SO cool! i've never seen that done on here. really classy. lovely wing too.
<div class='quotetop'>QUOTE (UrS0NvS @ Sep 8 2010, 11:19 PM) <{POST_SNAPBACK}></div><div class='quotemain'>where at in kansas?
im in wamego</div> Ive only lived here for bout 6 yrs so i dont know where your at, I know this lil SE corner over to Missouri. Coffeyville. <div class='quotetop'>QUOTE </div><div class='quotemain'>that is SO cool! i've never seen that done on here. really classy. lovely wing too.</div> beercheers.gif The wing i am really pround of because i had no help, installed by ME. I got the idea from a guy that has been on here before. As for the door poppers, I still need to install lil spring loaded poppers to open the door just a lil more. I have uploaded a vid to youtube just havent figd out how to post it here. |
what alot of the truck crowd guys are doing INSTEAD of welding on a patch panel to shave the handles
they are using the epoxy sh*t saturn's use to put on the body panels its a sand-able epoxy |
much better.
