how do i install brake rotors on 2k accent, help...
ok how do i install these, i mean are they as easy as changing out brake pads or what??
any input would be greatly appreciated!!! |
Got 15 minutes a wheel? Then you can replace your rotors.
Step #1. Loosen Lugs Step #2. Jack up car and put on jack stand Step #3. Remove lugs Step #4. Remove wheel Step #5. Remove 2 bolts holding caliper assembly to wheel hub. Step #6. Using zip ties or wire, place the caliper out of the way so you can work, yet not too far so that it stresses the brake line. Step #7. Grab the rotor on the left and right side, and pull towards you. Wiggle it left and right to get it off. Step #8. Install new Rotor Step #9. Remove the cover off the Brake fluid resoivor Step #10. using a C-Clamp. push the caliper piston back in. You can use the old brake pad as something to push on to move it back. DO NOT PUSH ON THE PISTON ITSELF, you can damage it. Step #11. Put cover back on Brake Fluid resivor. Step #12. Remove old pads from Caliper, install new pads. ONLY install rotors with new pads. Step #13. Install caliper on rotor Step #14. Install 2 bolts holding caliper to wheel hub Step #15. Install wheel Step #16. Finger tighten lug nuts Step #17. Jack up car, remove jack stand, lower car. Step #18. Torque down lug nuts to proper spec Repeat for other side. When done, bleed the brakes, staring at the passenger side rear, then drivers side rear, then passenger side front, then drivers side front. Keep bleeding each until you get 3 clean shots of fluid with no air in them. |
ok thanks for the info man!! you have been the only one i gotten a reply back from on the places i've posted this question!! :D |
