How connect Accent Temp Guage to Beta Engine
Attachment 945
fixed. Remove cluster. Far Right connector plug (Behide Fuel guage) Connect Blue Wire to the Single Connector Temp Sender on beta engine. (Duel sensor is for ECU) |
Am i right in thinking i should wire it diectly to the cluster. ?
On Rear.. Ground. 12V. Sensor. Ground and 12V are fine. So wire sensor directly to Sensor Wire. |
I would think yes.
The voices tell me you need the wiring to the computer also. There is at least one temperature sensor in the fuel control system. Wiring the gauge is all well & good but if you get bad fuel trim what's the point?
Looks like it shares the ground for the Primary O2 sensor and the positive comes form the ECU. The ECU runs the gage.
Iv since removed the stock ecu.
Is there anyways i can do to bypass this problem. I use a Megasquirt 2 V3.0 ECU for my beta swap. on all my wiring diagrams i don't have a temperature gauge Pin out. |
For beta wiring
http://i46.tinypic.com/16c8emv.jpg The Hyundai service website will not show me any images for my accent :( Will they hyundai Guage cluster be 12 Volts.. Because if ecu powers the Temperature gauge i will need to by pass it now. |
why not just run an separate universal temp gauge if that is your problem?
http://www.ebay.com/itm/universal-2-...2c0783&vxp=mtr |
Originally Posted by pas1216
(Post 676937)
http://www.ebay.com/itm/universal-2-...2c0783&vxp=mtr It would annoy me seeing the gauge doing northing.. |
as anyone got a diagram of the cluster/ coolent loom please.
