DMTL WIRING IS FAULTY 2002 ACCENT
check engine light comes on cant,put gas in at regular rate 1402 &1403 code comes up is there a easy way of getting this taken care of
From: https://www.hyundaiaftermarket.org/f...-engine-codes/
P1402 DMTL Motor Circuit P1403 DMTL Valve Circuit have you inspected the wiring and connections? This person had the same codes on the same model car and his module had a rusted/bad connector The slow filling at the pump is possibly related. On my RD platform, I had charcoal migrating from the canister and the valves were affected. It's all in the same area. You might pull the hoses and check for stray carbon before buying parts. https://www.justanswer.com/uploads/G...7_hyundai3.gif from justanswer.com Using Internet Explorer only, go get an account for yourself at https://www.hyundaitechinfo.com/ and go to the SHOP section. Navigate to: ACCENT(LC) >2002 > G 1.5 SOHC > Emission Control System > Evaporative Emission Control System > Diagnosis Module - Tank Leakage (DMTL) > Troubleshooting |
