Washer Pump
Vehicle: 2000/Hyundai/Accent
A couple months back my washer pump just stopped working, I tested the connections with a multimeter and it showed voltage and amperage. I got a new pump and It would work sometimes when I tapped it. Now there is no power at the connection for the pump.
I can't find any blown fuses or anything...
Any suggestions?
Any suggestions?
check the connectors, check for dirt and grease..
mine went bad and it was my 2nd one too, my old one was working but was broken due to a accident,
so i took the motor and glued it to the pump mechanism..with electric tape, zip tie's and silicone to make it waterproof
as for your problem, did u check fuse?..buy another pump and see if it's the same problem, since you can always return it if there's no fault with it
