turn signals/hazards no workie.
So before I went to Iraq in February, my hazards didn't work but my signals worked fine... Just got back 2 weeks ago, drove for about 3 days then my turn signals went out also. I checked every bulb, all filaments are fine. I replaced the flasher unit relay. I have tried between the two hazard switches I have, nothing. It is driving me insane. I completely disassembled a switch and cleaned it out, the factory grease was dirty, assembled and still nothing. I flip flopped the bulb in the hazard switch so that it lit up and still nothing. I checked the turn signal bulbs in the dash, they are fine. If I slightly engage the hazard switch just enough for the metal to make a connection, I can hear, and i put my hand on the flasher relay to verify, makes a small click, but nothing.
California highways are not a safe place to just have arm signals, someone please help so I can drive my car!!!!! cliffs.gif mad.gif Oh, and I verified that every fuse in the kick panel and under the hood are fine. |
Check fuses?
<div class='quotetop'>QUOTE(03-accent-03 @ Sep 29 2008, 12:18 AM) </div><div class='quotemain'>Check fuses?</div>
yep, unless there are hidden fuses. Are there??? I'll try about anything at this point. Almost ready to use a multimeter to do point to point continuity. |
So, just to clarify you replaced the flasher and turn signal relays?
Can you check for voltage, either in the power wire or before the fuse? That might be a starting to point to see where the power cut off is at.
<div class='quotetop'>QUOTE(Visionz @ Sep 29 2008, 08:45 AM) </div><div class='quotemain'>Can you check for voltage, either in the power wire or before the fuse? That might be a starting to point to see where the power cut off is at.</div>
I just printed some schematics off of hmaservice. I'll do some wire checking when i get off work. I'm sure I can answer my own question when I investigate in a few hours but, besides the flasher unit relay, are there seperate relays for the turn sigs? |
I had to replace one, I think there were two, one for the hazards and one for the turn signals...but I am not 100% sure on that actually...
<div class='quotetop'>QUOTE(187sks @ Sep 29 2008, 06:51 PM) </div><div class='quotemain'>I had to replace one, I think there were two, one for the hazards and one for the turn signals...but I am not 100% sure on that actually...</div>
i pulled the 3-prong hazard flasher relay out and got 12 somethin volts when i flipped the blinker lever on either direction with no volts in the middle position, i switched the negative multimeter lead to the third point and i got 12 volts with the hazard switch... aggravated beyond measure. |
I wonder if a plug in the wiring harness has come loose?
<div class='quotetop'>QUOTE(187sks @ Sep 29 2008, 09:17 PM) </div><div class='quotemain'>I wonder if a plug in the wiring harness has come loose?</div>
my model/year doesn't have a bcm does it? i couldnt find any info on one for it.... i'll go try to double check connections.... |
