Hyundai Aftermarket
-   HELP Forum (https://www.hyundaiaftermarket.org/forum/help-forum-21/)
-   -   Taking off alternator (https://www.hyundaiaftermarket.org/forum/help-forum-21/taking-off-alternator-9356/)
Kinalyx Jan 14, 2003 10:42 AM
Ive got my alternator off, after a whole lot of BS, such as having to remove the oil filter to get it out.
Now the wire clip is still plugged in, & i cant get the damn thing out.
Someone please help, all i need off is that clip.
Random Jan 14, 2003 02:00 PM
wire clip? There should just be a plastic push tab connector. If you push the tab in, the connector should pop off/out.
Kinalyx Jan 14, 2003 08:52 PM
Thx random, i noticed after i went back out, that the little push tab was broken.
I had to put a screwdriver in where the tab wuold have pushed the clip in to get it out.
Viper966 Jan 15, 2003 12:10 AM
yea doing the alternator was a PITA wait till u put it back on and have 2 set the tentions.. now ur tensioner bolt shouldnt move... hyundai set mine with locktite for some reason... so 2 get it on ur gonna have to push the alternator fwd until it fits.. i acomplished this with a long metal rod that i used 2 pry the alternator fwd on its pivit pt...
FlyRyde Jan 15, 2003 02:18 AM
I just pulled the oil filter off. Pulled that lil bioch off and strapped on a new one... no problems. Was I just lucky or do I have a problem with tension that I dont know about?
Random Jan 15, 2003 03:56 AM
<div class='quotetop'>QUOTE</div><div class='quotemain'>BlackTIbs:
do I have a problem with tension that I dont know about?</div>You might. If you have more than half an inch of free play (about 12mm) then yeah, you've got too much slack in your alternator belt. Check the slack in the belt, and adjust if necessary.
Viper-
Just make sure you don't OVER tighten the belt. It can wear out the bearings in the device (water pump, Alt, ac condensor, etc..etc.) and it can also wear out the belt much faster, in addition to putting excess drag on the motor.
