HELP Forum Car won't start, Spark Plug Melted? Car throwing sparks down as you drive down the road? Ask your car questions here.
Stuck fuel gauge
Old 03-10-2015, 10:45 AM
bigfishmoney's Avatar
Default Stuck fuel gauge
Filled my tank up and the indicator, after quite a bit of driving has not moved. Also replaced the instrument cluster a few months ago.
Old 03-10-2015, 07:56 PM
Stocker's Avatar
Has the gauge ever worked since the cluster was replaced?
Old 03-12-2015, 10:43 AM
yea
Old 03-12-2015, 06:47 PM
Stocker's Avatar
and did you change anything or do any wiring work on the car, since the last time the gauge worked?
Old 04-02-2015, 01:39 PM
No I did not. It actually started going down everything is correct. The instrument cluster is working in accordance with the fuel pump component
