Storing Tib, need help ASAP!
The white stuff is coming in a day or so, so I need to know what to do when Storing the tib
1. Fuel Stabilizer
- Do I need it?
- What does it do?
- Can I get away by not using it and just start the Tib up once a week or so?
2. Battery
- Should I unhook it?
- Or by starting it once a week,... will that be enough to keep the charge?
3. Oil
- Anything I need to do to it?
Again, if I can start it up every other week or so, and not have to put any type of additives that be kewl,... can't move it much within the garage, but I can back it up like 3 feet or so, with the garage door open, so I don't think I need to jack it up?
Any help would be kewl
Thanks!
1. Fuel Stabilizer
- Do I need it?
- What does it do?
2. Battery
3. Oil
Thanks!
If you plan to store your car for the winter or more than four weeks, use the following tips to prepare it for long-term storage:
1. Engine Protection. Fill the vehicle with oil and add enough antifreeze to provide protection up to 50 degrees below zero. You should drive your vehicle about 15 miles to heat the engine, which will circulate the oil and antifreeze through the system.
2. Fill 'Er Up. Fill the gas tank and add a fuel stabilizer to prevent the gasoline from oxidizing.
3. Rust Never Sleeps. By topping off the liquids like windshield washer fluid and brake fluid, you can prevent condensation from forming and rusting the internal chambers of your vehicle.
4. Wax On. Wash and wax your car to eliminate dirt and residue stains and to prevent corrosion.
5. Insider Info. If possible, select a dry, indoor storage facility for your vehicle. Sun, rain, snow, and bird droppings can damage your car's finish and promote rust. Severe weather, such as hail and high winds, can blow debris onto your car and cause body damage.
6. Cover Up. If you plan to store your car outside, use a strong, quality tarp to cover the entire vehicle.
7. Keep Weight Off. Use four jack stands to lift the vehicle completely off the ground. This relieves the weight of the vehicle, keeping the tires from developing flat spots. Position the jack stands under the axles to avoid damaging your vehicle's suspension.
8. Complete Disconnect. Disconnect the battery. You can detach one cable from the battery or remove the battery from the vehicle. Don't store your battery directly on concrete or metal. Instead, place it on wood to maintain its ability to hold a charge.
9. Inner Peace. Even inside, buy yourself peace of mind by covering your car with a tarp to prevent dust and moisture from damaging the car's finish and metal. This will also keep birds and mice from using your backseat as a winter home. Covers for indoor use only, resembling giant, airtight garment storage bags, are available to completely encase your vehicle.
10. That's What Friends Are For. If you're out of town, ask a friend to start the car every two to three weeks and let it run for five or 10 minutes. Remind them not to run a car in a garage without proper ventilation.
By following these tips your vehicle will look as good coming out as it did going in to storage. Keep in mind that by properly preparing your car for long-term storage, you can maintain its performance and value.
[ November 22, 2001: Message edited by: Mark D' Shark ]
