s-afc help
i wired up the s-afc the way random posted on a previous forum.......i have power to the s-afc, but the car won't run.....i read that AZZY hooked his pins in a different order.......does anyone know the correct order for the pins to hook up??????????
Did you count the wires and no go by color code?
If you went by color code, you most likely screwed up.
There is no order that I am aware of.
If the car wont start you might not have the ECU plugg in all the way, I would check that and check all your connections again.
I installed mine in liek 2 hours, it was a Piece of Cake.
do you remember the pin #'s that you went by????????if so what were they, or could you tell me where to find out where you found the chart for the pin #'s..........my car is gonna sit overnight and i'll attempt it again tomorrow.........thanks for your help
daaamn, colour on colour is a big nono!!!
You need to get random's diagram of the ecu harness, and sit and count the pins, then look on the back, find the wire and tap into it. Not the easiest and/or comfortable of mods, but definetly a learning experience wink
these are the pins you need to connect into. if you still dont have it working by the time i get home from work tonight ill crawl back under my dash and give you a color code guide.
remember that when you are lying upside down under your dash you are looking at this from a different angle, so what you think is the top is most likely the bottom. the best advice i can give is to count the wires 3 times, then splice.
heres a pic of the wiring diagram Apex'i gives.
