Removal of the back seat?
Old Dec 7, 2001 | 12:47 AM
Jaws99's Avatar
Default Removal of the back seat?
I want to remove the back seat (the part you sit on) but I can't seem to get it out. Is it held down by bolts? Do I just have to give it a good pull? Let me know and thanks in advance.
Old Dec 7, 2001 | 05:07 AM
Brendan's Avatar
There are 2 bolts holding it in, if you just pull forward a bit on the back of the seat ( under the vertical part ) you should see them, 14mm bolt heads that go right into the body, that those 2 bolts out, pull up and it flips over, then there should be 4 clips which you just use pliers to compress and lift out ( DO NOT BREAK THEM ) and no lower back seat.
Old Dec 7, 2001 | 07:57 AM
Jaws99's Avatar
Thank you. Came out without a hitch but the bolts were 13 not 14 thanks for the wrong info jk lol. You were a big help I wouldn't have even looked for them there. Thanks again
Old Dec 7, 2001 | 07:59 AM
Brendan's Avatar
13 / 14 same difference lol
Old Dec 7, 2001 | 12:25 PM
Iago's Avatar
It is when you're forced to use SAE tools on a metric car!
Old Dec 8, 2001 | 01:33 AM
Just get a Metrench set. No more worries about SAE/metric.
Old Dec 9, 2001 | 09:14 AM
Fast.Type-S's Avatar
What's the total weight for the back seating? I have a little idea in the back of my head brewing....
Old Dec 10, 2001 | 08:20 AM
The both seat backs and the bottom part are probably about 50 or 60 lbs, including all bracket components seatbelts and such.
Old Dec 10, 2001 | 09:17 AM
Choopi's Avatar
Old Dec 10, 2001 | 03:12 PM
Originally posted by Choopi:
PICS PICS PICS?!?!?!?!?!?
Of what? How to remove your rear seats? http://www.hmaservice.com/webtech/iindex.a...id=12240#_12240
