Hyundai Aftermarket
-   HELP Forum (https://www.hyundaiaftermarket.org/forum/help-forum-21/)
-   -   Radiator wiring help needed (https://www.hyundaiaftermarket.org/forum/help-forum-21/radiator-wiring-help-needed-76180/)
bigfishmoney Feb 2, 2014 02:37 PM
using a ohmmeter what continuity should i get between the radiator fan wire harness clip and wires in the engine bay? or can they be wired either way?
bigfishmoney Feb 2, 2014 02:40 PM
i need the voltage reading for proper operation as the engine may adjust voltages and cause overheating if its wired backwards.
Thanks
JonGTR Feb 2, 2014 04:04 PM
They get 12v constant and receive ground to turn on.
bigfishmoney Feb 3, 2014 03:33 AM
Thank you
bigfishmoney Feb 12, 2014 01:33 PM
my original problem was if the wires are backwards or not guess that does not matter thanks jongtr...
bigfishmoney Aug 20, 2014 11:45 AM
Does this mean that it does not matter which way the wires are spliced back together?
bigfishmoney Aug 30, 2014 05:39 PM
fixed
