No Clock..Int lights...
Old Oct 1, 2001 | 01:51 PM
Fast.Type-S's Avatar
Default No Clock..Int lights...
Weird thing happend..While installing my Front SR bar...I blew a fuse of some type. Now my clock/Interiro lights/Rear trunk light...dont work..Which fuse needs replacing...if thats it...hopefully...dont feel like wiring my own custom lighting system right now. But maybe in the near future..hehe..any thoughts?
Old Oct 1, 2001 | 02:14 PM
Canadian Prairie Shark's Avatar
I have blown the same one 2 times! It is marked as the sun roof fuse. Should be a red 10 amp fuse. Down by the front of the drivers door. It will be on the left hand side of the 2 rows of fuses. About mid way through.
Hope that helps you, considering I just replaced mine last night.
Old Oct 1, 2001 | 02:49 PM
WIGGLE's Avatar
I did the same thing.... it's the 6th fuse down... you have a replacemt in there for it...
Old Oct 2, 2001 | 12:24 AM
Both of you blew this fuse installing your SR bars? Why/how did this happen? Weird. Thanks for the info. Now @ lunch tinme I will have my clock back. Thanks for the info.
Old Oct 2, 2001 | 03:12 PM
None of my fuses are blown? Hrmm..any other thoughts?
Old Oct 2, 2001 | 08:04 PM
Did you replace the fuse anyway? Sometimes the fuze looks okay, when it is not.
